Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Whirlpool Refrigerator Freezer Thermistor Replacement
Qué necesitas
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: paso 3, imagen 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: paso 3, imagen 2 de 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: paso 4, imagen 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement: paso 4, imagen 2 de 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: paso 5, imagen 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: paso 5, imagen 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: paso 5, imagen 3 de 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: paso 6, imagen 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: paso 6, imagen 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: paso 6, imagen 3 de 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: paso 7, imagen 1 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: paso 7, imagen 2 de 3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: paso 7, imagen 3 de 3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: paso 8, imagen 1 de 2 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: paso 8, imagen 2 de 2
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: paso 9, imagen 1 de 1
    • Remove the thermistor.
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: paso 10, imagen 1 de 1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
2 personas más completaron esta guía.
nicO
Miembro Desde 04/14/15
15,990 Reputación
89 Guías creadas
1Guía Comentario
Does anyone know the thermistor part number it’s not listed on the parts breakdown
Tony - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 34
Ultimos 30 días: 151
Todo El Tiempo: 4,556
