Saltar al contenido principal
Whirlpool Refrigerator Evaporator Fan Replacement
Qué necesitas
  1. Whirlpool Refrigerator Evaporator Fan Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: paso 3, imagen 1 de 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: paso 3, imagen 2 de 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Evaporator Fan Replacement: paso 4, imagen 1 de 2 Whirlpool Refrigerator Evaporator Fan Replacement: paso 4, imagen 2 de 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: paso 5, imagen 1 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: paso 5, imagen 2 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: paso 5, imagen 3 de 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: paso 6, imagen 1 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: paso 6, imagen 2 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: paso 6, imagen 3 de 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: paso 7, imagen 1 de 2 Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: paso 7, imagen 2 de 2
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire(s) attached to the evaporator fan.
  8. Whirlpool Refrigerator Evaporator Fan Replacement: paso 8, imagen 1 de 3 Whirlpool Refrigerator Evaporator Fan Replacement: paso 8, imagen 2 de 3 Whirlpool Refrigerator Evaporator Fan Replacement: paso 8, imagen 3 de 3
    • Disconnect any connectors attached to the evaporator fan.
  9. Whirlpool Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan: paso 9, imagen 1 de 1
    • Remove the screw(s) securing the evaporator fan.
  10. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: paso 10, imagen 1 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: paso 10, imagen 2 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: paso 10, imagen 3 de 3
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure any remaining foam buffers.
  11. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: paso 11, imagen 1 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: paso 11, imagen 2 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: paso 11, imagen 3 de 3
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: paso 12, imagen 1 de 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: paso 12, imagen 2 de 2
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: paso 13, imagen 1 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: paso 13, imagen 2 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: paso 13, imagen 3 de 3
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: paso 14, imagen 1 de 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: paso 14, imagen 2 de 2
    • Remove the motor bracket.
  15. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: paso 15, imagen 1 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: paso 15, imagen 2 de 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: paso 15, imagen 3 de 3
    • Pull the motor straight out of its housing to remove it.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 57
Ultimos 30 días: 253
Todo El Tiempo: 2,089
