Saltar al contenido principal
Whirlpool Refrigerator Door Sensor Replacement
Qué necesitas
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: paso 1, imagen 1 de 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: paso 1, imagen 2 de 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: paso 1, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: paso 2, imagen 1 de 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: paso 2, imagen 2 de 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: paso 2, imagen 3 de 3
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: paso 3, imagen 1 de 2 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: paso 3, imagen 2 de 2
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: paso 4, imagen 1 de 2 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: paso 4, imagen 2 de 2
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 27
Ultimos 30 días: 140
Todo El Tiempo: 1,023
