Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Whirlpool Refrigerator Defrost Heater Replacement
Qué necesitas
  1. Whirlpool Refrigerator Defrost Heater Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: paso 3, imagen 1 de 2 Whirlpool Refrigerator Defrost Heater Replacement, Remove the drawers: paso 3, imagen 2 de 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Defrost Heater Replacement: paso 4, imagen 1 de 2 Whirlpool Refrigerator Defrost Heater Replacement: paso 4, imagen 2 de 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: paso 5, imagen 1 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: paso 5, imagen 2 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Unclip the evaporator cover: paso 5, imagen 3 de 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: paso 6, imagen 1 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: paso 6, imagen 2 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Remove the evaporator cover: paso 6, imagen 3 de 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: paso 7, imagen 1 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: paso 7, imagen 2 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Disconnect the defrost heater: paso 7, imagen 3 de 3
    • Disconnect the connector(s) attached to the defrost heater.
  8. Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: paso 8, imagen 1 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: paso 8, imagen 2 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Reposition the cable: paso 8, imagen 3 de 3
    • Pull the defrost heater cable out from behind the evaporator.
  9. Whirlpool Refrigerator Defrost Heater Replacement, Unfasten the defrost heater bracket: paso 9, imagen 1 de 1
    • Remove the screw(s) securing the defrost heater bracket.
  10. Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: paso 10, imagen 1 de 2 Whirlpool Refrigerator Defrost Heater Replacement, Release the defrost heater bracket: paso 10, imagen 2 de 2
    • Pull the defrost heater bracket up to release it from its slot in the chassis.
  11. Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: paso 11, imagen 1 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: paso 11, imagen 2 de 3 Whirlpool Refrigerator Defrost Heater Replacement, Remove the defrost heater: paso 11, imagen 3 de 3
    • Slide the defrost heater from under the evaporator.
    • You may need to pull one end at a time until it's completely removed.
  12. Whirlpool Refrigerator Defrost Heater Replacement, Only the defrost heater remains: paso 12, imagen 1 de 1
    • You're now left with the defrost heater.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
5 personas más completaron esta guía.
nicO
Miembro Desde 04/14/15
15,990 Reputación
89 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 79
Ultimos 30 días: 239
Todo El Tiempo: 6,428
