Introducción
Use this guide to remove or replace the power cable on a Wacker PST2 400 (2008) Submersible Pump.
Qué necesitas
Pull to remove the two cotter pins securing the hose's locking arms, one on either side.
Use a 10 mm socket to remove the two bolts securing the handle to the housing cover.
Use an 8 mm socket to remove the two bolts securing the power cable to the housing cover.
Use a 10 mm socket to remove the three bolts securing the housing cover to the main body.
Use a pair of needle nose pliers to disconnect the ground wire's bullet connector.
Use a pair of needle nose pliers to disconnect the red and white power wires' bullet connectors.
Connect the power cord's black wire to the device's red wire
Connect the green ground wires together
Connect the white wires together
Pull the loose power cable out through its hole on the housing cover to remove it.
2 personas más completaron esta guía.
3 comentarios
Hola que tipo de aceite lleva la PST2 400 de 1/2 HP ,y cuanto?
El manual de usuario del fabricante indica que esta bomba utiliza 160 ml (5,4 fl oz) de aceite SAE 10W/20W. También dice que debe reemplazarse cada 2000 horas o 12 meses, lo que ocurra primero.
