Saltar al contenido principal
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
Qué necesitas
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: paso 1, imagen 1 de 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: paso 1, imagen 2 de 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: paso 2, imagen 1 de 1
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: paso 3, imagen 1 de 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: paso 3, imagen 2 de 2
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: paso 4, imagen 1 de 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: paso 4, imagen 2 de 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: paso 4, imagen 3 de 3
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: paso 5, imagen 1 de 1
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: paso 6, imagen 1 de 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: paso 6, imagen 2 de 3 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: paso 6, imagen 3 de 3
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
Conclusión
Arthur Shi
Miembro Desde 01/03/18
254,326 Reputación
529 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,303 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 3,020
