Saltar al contenido principal
Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement
Qué necesitas
  1. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: paso 1, imagen 1 de 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Safety precautions: paso 1, imagen 2 de 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: paso 2, imagen 1 de 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Loosen the handle: paso 2, imagen 2 de 2
    • For ease of access, swing the transport wheels underneath the plate compactor before you begin.
    • Use a 3/4" wrench to remove the two nuts securing the handle.
    • Use your palm to push against the shockmount to prevent it from slipping.
    • Remove the nuts and washers and retain them for reassembly.
  3. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: paso 3, imagen 1 de 3 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: paso 3, imagen 2 de 3 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Lower the handle: paso 3, imagen 3 de 3
    • Tilt the guide handle forward to pivot the shockmount bolts out of the base grooves.
    • Slide the guide handle down enough to access the shockmounts.
  4. Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: paso 4, imagen 1 de 2 Wacker Compactor Plate VP1550AW 2014 Shockmount Replacement, Remove the shockmount: paso 4, imagen 2 de 2
    • Pull the shockmount out of the guide handle.
Conclusión
Arthur Shi
Miembro Desde 01/03/18
252,813 Reputación
526 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 475
