Introducción
Use this guide to replace the temperature control board in your Whirlpool WRS315SDHW Refrigerator.
The temperature control board regulates the temperature throughout the refrigerator. If your refrigerator is not cooling properly, your temperature control board might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Qué necesitas
Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly.
Pull the temperature control board assembly off its slot in the chassis.
Let the assembly hang to access its connectors.
Disconnect the two spade connectors attached to the temperature control board assembly.
Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
Use another flathead screwdriver to pry up the board from its housing.
Pull the temperature control board straight out of its housing to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
Una persona más ha completado esta guía.
