Saltar al contenido principal
WRS315SDHW Defrost Thermistor Replacement
Qué necesitas
  1. WRS315SDHW Defrost Thermistor Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Thermistor Replacement, Open the doors: paso 2, imagen 1 de 3 WRS315SDHW Defrost Thermistor Replacement, Open the doors: paso 2, imagen 2 de 3 WRS315SDHW Defrost Thermistor Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: paso 3, imagen 1 de 2 WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: paso 3, imagen 2 de 2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Thermistor Replacement: paso 4, imagen 1 de 2 WRS315SDHW Defrost Thermistor Replacement: paso 4, imagen 2 de 2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: paso 5, imagen 1 de 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: paso 5, imagen 2 de 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: paso 5, imagen 3 de 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: paso 6, imagen 1 de 3 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: paso 6, imagen 2 de 3 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: paso 6, imagen 3 de 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: paso 7, imagen 1 de 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: paso 7, imagen 2 de 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: paso 7, imagen 3 de 3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: paso 8, imagen 1 de 2 WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: paso 8, imagen 2 de 2
    • Disconnect the thermistor from the wiring harness.
  9. WRS315SDHW Defrost Thermistor Replacement, Remove the thermistor: paso 9, imagen 1 de 1
    • Remove the thermistor.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Una persona más ha completado esta guía.
nicO
Miembro Desde 04/14/15
15,927 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
34 Miembros
596 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 132
