Saltar al contenido principal
Vizio SmartCast Crave 360 Speaker Ring Replacement
Qué necesitas
  1. Vizio SmartCast Crave 360 Speaker Ring Replacement, Speaker Ring: paso 1, imagen 1 de 1
    • Place the speaker so that the speaker volume ring faces up.
  2. Vizio SmartCast Crave 360 Speaker Ring Replacement: paso 2, imagen 1 de 2 Vizio SmartCast Crave 360 Speaker Ring Replacement: paso 2, imagen 2 de 2
    • Using the halberd spudger, pop off the metal disc that is connected to the speaker ring.
    • Remove the metal disc.
    • Ignore the small circuit board that is under the metal disc. It is not important for this replacement.
  3. Vizio SmartCast Crave 360 Speaker Ring Replacement: paso 3, imagen 1 de 1
    • Remove the four 5mm screws that connect the inner bearing to the outer ring using a Phillips #000 screwdriver.
  4. Vizio SmartCast Crave 360 Speaker Ring Replacement: paso 4, imagen 1 de 2 Vizio SmartCast Crave 360 Speaker Ring Replacement: paso 4, imagen 2 de 2
    • Take the outer ring and inner bearing off of the speaker.
    • Remove the outer ring from the inner bearing and plastic disc.
  5. Vizio SmartCast Crave 360 Speaker Ring Replacement: paso 5, imagen 1 de 1
    • Remove the inner bearing from the plastic disc so that all three components of the speaker ring are separated.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 263
