Saltar al contenido principal
Vizio SmartCast Crave 360 Battery Replacement
Qué necesitas
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: paso 1, imagen 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: paso 3, imagen 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: paso 3, imagen 2 de 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: paso 4, imagen 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Bass: paso 4, imagen 2 de 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: paso 5, imagen 1 de 3 Vizio SmartCast Crave 360 Battery Replacement: paso 5, imagen 2 de 3 Vizio SmartCast Crave 360 Battery Replacement: paso 5, imagen 3 de 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: paso 6, imagen 1 de 2 Vizio SmartCast Crave 360 Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: paso 7, imagen 1 de 1
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: paso 8, imagen 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: paso 8, imagen 2 de 2
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: paso 9, imagen 1 de 2 Vizio SmartCast Crave 360 Battery Replacement: paso 9, imagen 2 de 2
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: paso 10, imagen 1 de 1
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: paso 11, imagen 1 de 1
    • Remove the motherboard from the battery.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 64
Todo El Tiempo: 951
