Introducción
If your Vizio SmartCast Crave 360 (model SP50-DP) is making a muffled, fuzzy, or crackling sound, follow this guide to replace the bass component. A bass woofer producers the lower frequencies of music and sounds. A weak or broken bass woofer will create an unpleasant buzzing and scratching noise.
Before beginning, remove the Crave 360 from its charging base and turn off the device.
Qué necesitas
Orient the speaker so that the bottom faces up.
Peel the rubber ring off of the bottom using the spudger.
4 personas más completaron esta guía.
