Saltar al contenido principal
Vizio SmartCast Crave 360 Bass Replacement
Qué necesitas
  1. Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: paso 1, imagen 1 de 2 Vizio SmartCast Crave 360 Bass Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Bass Replacement: paso 2, imagen 1 de 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Bass Replacement: paso 3, imagen 1 de 2 Vizio SmartCast Crave 360 Bass Replacement: paso 3, imagen 2 de 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Bass Replacement, Bass: paso 4, imagen 1 de 2 Vizio SmartCast Crave 360 Bass Replacement, Bass: paso 4, imagen 2 de 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Bass Replacement: paso 5, imagen 1 de 3 Vizio SmartCast Crave 360 Bass Replacement: paso 5, imagen 2 de 3 Vizio SmartCast Crave 360 Bass Replacement: paso 5, imagen 3 de 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 615
