Saltar al contenido principal
Vizio CT15 Speaker Replacement
Qué necesitas
  1. Vizio CT15 Speaker Replacement, Vizio CT15 Back Panel Removal: paso 1, imagen 1 de 2 Vizio CT15 Speaker Replacement, Vizio CT15 Back Panel Removal: paso 1, imagen 2 de 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Speaker Replacement, Battery: paso 2, imagen 1 de 1
  3. Vizio CT15 Speaker Replacement: paso 3, imagen 1 de 2 Vizio CT15 Speaker Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Speaker Replacement, Speakers: paso 4, imagen 1 de 2 Vizio CT15 Speaker Replacement, Speakers: paso 4, imagen 2 de 2
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Speaker Replacement: paso 5, imagen 1 de 2 Vizio CT15 Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Speaker Replacement: paso 6, imagen 1 de 3 Vizio CT15 Speaker Replacement: paso 6, imagen 2 de 3 Vizio CT15 Speaker Replacement: paso 6, imagen 3 de 3
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Speaker Replacement: paso 7, imagen 1 de 2 Vizio CT15 Speaker Replacement: paso 7, imagen 2 de 2
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 369
