Saltar al contenido principal
Vizio CT15 Battery Replacement
Qué necesitas
  1. Vizio CT15 Battery Replacement, Vizio CT15 Back Panel Removal: paso 1, imagen 1 de 2 Vizio CT15 Battery Replacement, Vizio CT15 Back Panel Removal: paso 1, imagen 2 de 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Battery Replacement, Battery: paso 2, imagen 1 de 1
  3. Vizio CT15 Battery Replacement: paso 3, imagen 1 de 2 Vizio CT15 Battery Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
Conclusión
2 personas más completaron esta guía.
Un comentario
In case anyone comes across this page looking for the CMOS Battery, it is an ML1220 Battery. I found a comparable replacement of "LeFix ML1220 Rechargeable CMOS Battery Replacement Compatible with ASUS EEE PC 1101HA 1005HA T101MT 1101HAB 1005P,Acer Aspire 5920 5920G 5920 G Series,Fujitsu Amilo Pi 3560 3660 LI3710 LI3910" on Amazon (https://www.amazon.com/LeFix-Rechargeabl...)
Image: https://photos.app.goo.gl/hcaVn8TJUCFbXr...
Image: https://photos.app.goo.gl/ubCpmQMT4Rb5h1...
PaulIsaacsonSh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 989
