Saltar al contenido principal
Velocity Micro Cruz T301 Battery Replacement
Qué necesitas
  1. Velocity Micro Cruz T301 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Insert the plastic iFixit opening tool into the SD port. Orient the iFixit opening tool so that the edge faces the rear panel.
  2. Velocity Micro Cruz T301 Battery Replacement: paso 2, imagen 1 de 1
    • Use the iFixit opening tools to pry open a gap between the tablet and rear panel.
  3. Velocity Micro Cruz T301 Battery Replacement: paso 3, imagen 1 de 2 Velocity Micro Cruz T301 Battery Replacement: paso 3, imagen 2 de 2
    • Move the small tool opener around the rear panel to free the 12 clips.
  4. Velocity Micro Cruz T301 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the four screws in the metal battery housing using the Phillips #0 screwdriver.
  5. Velocity Micro Cruz T301 Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery using the spudger.
  6. Velocity Micro Cruz T301 Battery Replacement: paso 6, imagen 1 de 1
    • Lift the battery out of its place with a nylon spudger.
    • This photo shows the use of an incorrect tool. Always use an ESD safe tool, like the nylon spudger, when dealing with delicate components.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-6, Cagle Fall 2016 Miembro de USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 529
