Introducción
You will need knowledge of how to use a soldering iron. For more information regarding soldering visit: Soldering Skills
Used for mother board replacement and repair If the unit starts behaving erratically. Along the process you will determine if the behavior is not due to a faulty power jack, wires, and or microphone. If so proceed with motherboard replacement.
Qué necesitas
Along the back of unit there are two 4mm philips head screws towards the bottom of the unit. Start by removing these two screws using your PH0 screwdriver.
Remove the strip of adhesive tape located under the motherboard.
Gently lift the motherboard to expose the inner components.
Use a spudger to scrape away the adhesive and foam connecting the microphone.
Unscrew the 4mm phillips head screw holding the microphone in place.
De-solder the connections from the motherboard using a soldering iron and a solder sucker.
De-solder the connections to the microphone, located on the bottom left of the mother board.
De-solder the 4 wires connecting the LED board to the motherboard.
De-solder the antenna's solder joint, located above the microphone wire connection.
