Saltar al contenido principal
VTech InnoTab 2 Headphone Jack Replacement
Qué necesitas
  1. VTech InnoTab 2 Headphone Jack Replacement, Battery: paso 1, imagen 1 de 3 VTech InnoTab 2 Headphone Jack Replacement, Battery: paso 1, imagen 2 de 3 VTech InnoTab 2 Headphone Jack Replacement, Battery: paso 1, imagen 3 de 3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Headphone Jack Replacement, Back Panel: paso 2, imagen 1 de 3 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: paso 2, imagen 2 de 3 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: paso 2, imagen 3 de 3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Headphone Jack Replacement: paso 3, imagen 1 de 3 VTech InnoTab 2 Headphone Jack Replacement: paso 3, imagen 2 de 3 VTech InnoTab 2 Headphone Jack Replacement: paso 3, imagen 3 de 3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Headphone Jack Replacement: paso 4, imagen 1 de 2 VTech InnoTab 2 Headphone Jack Replacement: paso 4, imagen 2 de 2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Headphone Jack Replacement: paso 5, imagen 1 de 2 VTech InnoTab 2 Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
  6. VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: paso 6, imagen 1 de 3 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: paso 6, imagen 2 de 3 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: paso 6, imagen 3 de 3
    • Remove the two 7 mm screws from the left bumper of the device using a JO screwdriver.
    • Be careful not to pull to hard when removing the bumper to avoid damage to the circuit.
  7. VTech InnoTab 2 Headphone Jack Replacement: paso 7, imagen 1 de 3 VTech InnoTab 2 Headphone Jack Replacement: paso 7, imagen 2 de 3 VTech InnoTab 2 Headphone Jack Replacement: paso 7, imagen 3 de 3
    • Use your fingers to gently remove the headphone jack.
    • De-solder the points shown to fully remove the headphone jack from the motherboard.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills
Conclusión
Roberto Valdes
Miembro Desde 10/18/17
302 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G85, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 223
