Saltar al contenido principal
Using the 3DS's Safe Mode
  1. Using the 3DS's Safe Mode, Booting safe mode: paso 1, imagen 1 de 1
    • Ensure the console is powered off
    • Hold the (L) + (R) + (A) + (D-Pad Up) buttons
    • Keep these buttons held down until the console boots in the next step
    • While still holding the other buttons, press the power button
  2. Using the 3DS's Safe Mode, Updating the System: paso 2, imagen 1 de 3 Using the 3DS's Safe Mode, Updating the System: paso 2, imagen 2 de 3 Using the 3DS's Safe Mode, Updating the System: paso 2, imagen 3 de 3
    • You should boot into a "system update" screen. Click OK and accept the prompts
    • If there's no working internet connection configured on your 3ds, you'll have the option to set one up now
  3. Using the 3DS's Safe Mode: paso 3, imagen 1 de 1
    • When the update finishes, the console will automatically turn off
Conclusión
If your issue persists after following this guide, a system format may fix it. Or, if you'd prefer to keep your data, you can ask a question
darth mango
Miembro Desde 03/13/23
2,327 Reputación
3 Guías creadas
Equipo
Kid fixers Miembro de Kid fixers
Community
172 Miembros
229 Guías creadas
4 comentarios
Does this work on old family 3ds?
maxxy waxxy - Contestar
Works on every 3ds and 2ds model
darth mango -
Hello Darth mango. I have had my 3ds xl (red btw) since 2016. It stopped working in 19 and I gave up. Never knew why, but when I tried this it didn't work. I see u have a reputation for fixing this stuff and I followed EVERY one of our guides. Nothing works. Should I just just go get it repaired, because NOTHING will work, even this.
Jahasen :D - Contestar
Can you post a question about this? I try to avoid troubleshooting in comments as opposed to the forum made for it. Remember to include any symptoms (what happens when you plug it in, try to turn it on, etc.) as well as what fixes you've already tried. The better the info you give us, the better we'll be able to help. :D
darth mango -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 32
Ultimos 30 días: 184
Todo El Tiempo: 3,889
