Introducción
Follow this guide to disconnect the battery in your iPad Pro 12.9" 4th generation.
Qué necesitas
Use your Phillips screwdriver to remove the five screws securing the lower cable shield:
Four 1.1 mm screws
One 2.0 mm screw
Herramienta utilizada en este paso:Tweezers$4.99
Use tweezers or your fingers to grab and remove the lower cable shield.
Use your Phillips screwdriver to remove the 1.7 mm screw securing the battery connector to the logic board.
Casi Terminas!
Conclusión
