Saltar al contenido principal
Toshiba Canvio Connect V73600-C Disassembly
Qué necesitas
  1. Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: paso 1, imagen 1 de 2 Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: paso 1, imagen 2 de 2
    • On the side of your hard drive casing, insert a spudger.
    • This can be tricky as the tolerances are quite tight.
    • I used a needle to make the gap big enough to insert a pick.
  2. Toshiba Canvio Connect V73600-C Disassembly, Continue opening: paso 2, imagen 1 de 1
    • Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
  3. Toshiba Canvio Connect V73600-C Disassembly, Keep going: paso 3, imagen 1 de 1
    • Slide the spudger around the corner of the casing to start opening the next side.
    • There may be a gap big enough to see the plastic clips holding the device together.
  4. Toshiba Canvio Connect V73600-C Disassembly, Prise the casing open: paso 4, imagen 1 de 1
    • Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
    • This will reveal the hard drive in the casing.
  5. Toshiba Canvio Connect V73600-C Disassembly, Extract the hard drive: paso 5, imagen 1 de 1
    • Simply lift the drive out of the case.
    • There may be some friction due to the anti-shock rubber on the corners of the drive.
    • Gently pry with a plastic pry tool if required.
  6. Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: paso 6, imagen 1 de 3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: paso 6, imagen 2 de 3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: paso 6, imagen 3 de 3
    • As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
Conclusión
2 personas más completaron esta guía.
CONVERSION
Miembro Desde 03/07/20
1,252 Reputación
8 Guías creadas
Equipo
Australia Miembro de Australia
Community
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 30
Ultimos 30 días: 157
Todo El Tiempo: 4,792
