Introducción
This guide shows how to remove and replace the cylinder and cutting wedge assembly on the Toro Log Splitter 22618HD 2019 / LS-922.
For the amount of hydraulic fluid lost during this procedure, refill the hydraulic fluid tank.
Qué necesitas
Push the control valve lever towards the rear of the device to extend the piston and advance the cutting wedge.
Use an impact wrench with a 3/4 inch socket to loosen the twelve bolts and twelve nuts securing the slide bars to the underside of the cutting wedge.
Flip the red engine ON/OFF switch to the ON position.
Pull the motor's pull-start cable to start the motor.
Use the control valve lever to retract the cutting wedge until it is seated underneath the dislodger bracket.
Place a bucket underneath the device, below the cylinder to catch any hydraulic fluid drips.
Use an adjustable wrench to loosen the nut securing the piston extension hose to the L-fitting on the side of the cylinder.
Shim the cylinder with wood blocks to keep it at its resting height, parallel to the frame.
Pull to remove the two cotter pins securing the large pivot pin.
Shift the cylinder and wedge assembly towards the rear of the device, until it clears the central pin hole.
Support the cylinder and push the assembly towards the rear of the device until it clears the dislodger bracket.
3 personas más completaron esta guía.
