Saltar al contenido principal
Toro Cement Mixer 68009HD 2018 Tub Replacement
Qué necesitas
  1. Toro Cement Mixer 68009HD 2018 Tub Replacement, Safety precautions: paso 1, imagen 1 de 2 Toro Cement Mixer 68009HD 2018 Tub Replacement, Safety precautions: paso 1, imagen 2 de 2
    • Before you begin, press the engine-stop switch to turn off the engine.
  2. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 2, imagen 1 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 2, imagen 2 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 2, imagen 3 de 3
    • Unlatch the three rubber straps securing the cowl.
  3. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 3, imagen 1 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 3, imagen 2 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 3, imagen 3 de 3
    • Swing the cowl up until it rests securely on the frame.
  4. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 4, imagen 1 de 2 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 4, imagen 2 de 2
    • Slide the fuel cutoff lever to the left to cut the fuel supply to the engine.
  5. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 5, imagen 1 de 2 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 5, imagen 2 de 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  6. Toro Cement Mixer 68009HD 2018 Tub Replacement, Remove the tub: paso 6, imagen 1 de 2 Toro Cement Mixer 68009HD 2018 Tub Replacement, Remove the tub: paso 6, imagen 2 de 2
    • Pull up on the brake lever to disengage the brake.
  7. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 7, imagen 1 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 7, imagen 2 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 7, imagen 3 de 3
    • Rotate the tub until the yoke and dish assembly sit directly below the tub.
  8. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 8, imagen 1 de 2 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 8, imagen 2 de 2
    • Push down on the brake lever to re-engage the brake.
    • Make sure that the brake is fully engaged.
  9. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 9, imagen 1 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 9, imagen 2 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 9, imagen 3 de 3
    • Use a 3/4 inch socket to remove the six nuts securing the tub to the dish.
  10. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 10, imagen 1 de 1
    • Remove the six drum clamp plates from the tub mounting points.
  11. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 11, imagen 1 de 1
    • Lift the tub up slightly by the gear ring to loosen the tub from the dish.
  12. Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 12, imagen 1 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 12, imagen 2 de 3 Toro Cement Mixer 68009HD 2018 Tub Replacement: paso 12, imagen 3 de 3
    • The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
    • Lift the tub straight up from the dish and remove it from the device.
Conclusión
Arthur Shi
Miembro Desde 01/03/18
258,835 Reputación
531 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,052 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 250
