Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: paso 1, imagen 1 de 3 Toilet Flapper Replacement, Tank Lid: paso 1, imagen 2 de 3 Toilet Flapper Replacement, Tank Lid: paso 1, imagen 3 de 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: paso 2, imagen 1 de 2 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: paso 2, imagen 2 de 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: paso 3, imagen 1 de 2 Toilet Flapper Replacement, Draining a Toilet Tank: paso 3, imagen 2 de 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: paso 4, imagen 1 de 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: paso 4, imagen 2 de 3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: paso 4, imagen 3 de 3
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: paso 5, imagen 1 de 3 Toilet Flapper Replacement, Flapper: paso 5, imagen 2 de 3 Toilet Flapper Replacement, Flapper: paso 5, imagen 3 de 3
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
Conclusión
7 personas más completaron esta guía.
Kristen Gismondi
Miembro Desde 11/12/14
105,560 Reputación
266 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
25,548 Guías creadas
2Guía Comentarios
Thank you I needed that
My Mama - Contestar Compartir
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 80
Ultimos 30 días: 311
Todo El Tiempo: 18,001
