Saltar al contenido principal
Toilet Fill Valve Replacement
Qué necesitas
  1. Toilet Fill Valve Replacement, Tank Lid: paso 1, imagen 1 de 3 Toilet Fill Valve Replacement, Tank Lid: paso 1, imagen 2 de 3 Toilet Fill Valve Replacement, Tank Lid: paso 1, imagen 3 de 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Fill Valve Replacement, Shutting off the Water Supply to a Toilet: paso 2, imagen 1 de 2 Toilet Fill Valve Replacement, Shutting off the Water Supply to a Toilet: paso 2, imagen 2 de 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Fill Valve Replacement, Refill Tube: paso 3, imagen 1 de 3 Toilet Fill Valve Replacement, Refill Tube: paso 3, imagen 2 de 3 Toilet Fill Valve Replacement, Refill Tube: paso 3, imagen 3 de 3
    • Disconnect the fill valve's rubber refill tube from the top of the overflow tube.
  4. Toilet Fill Valve Replacement, Draining a Toilet Tank: paso 4, imagen 1 de 2 Toilet Fill Valve Replacement, Draining a Toilet Tank: paso 4, imagen 2 de 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  5. Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: paso 5, imagen 1 de 3 Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: paso 5, imagen 2 de 3 Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: paso 5, imagen 3 de 3
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
  6. Toilet Fill Valve Replacement, Supply Tube: paso 6, imagen 1 de 3 Toilet Fill Valve Replacement, Supply Tube: paso 6, imagen 2 de 3 Toilet Fill Valve Replacement, Supply Tube: paso 6, imagen 3 de 3
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  7. Toilet Fill Valve Replacement, Fill Valve: paso 7, imagen 1 de 2 Toilet Fill Valve Replacement, Fill Valve: paso 7, imagen 2 de 2
    • Using an adjustable wrench, turn the locknut on the threaded shank counter-clockwise until it becomes loose.
  8. Toilet Fill Valve Replacement: paso 8, imagen 1 de 3 Toilet Fill Valve Replacement: paso 8, imagen 2 de 3 Toilet Fill Valve Replacement: paso 8, imagen 3 de 3
    • Turn the locknut counter-clockwise until it releases from the threaded shank.
  9. Toilet Fill Valve Replacement: paso 9, imagen 1 de 2 Toilet Fill Valve Replacement: paso 9, imagen 2 de 2
    • Lift the entire fill valve out of the tank.
    • When installing a new valve, be sure to adjust the float so that the water line stops one inch below the overflow tube.
Conclusión
11 personas más completaron esta guía.
Kristen Gismondi
Miembro Desde 11/12/14
77,532 Reputación
184 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
142 Miembros
16,235 Guías creadas
4 comentarios
Great guide for removing the fill valve, but we're missing the steps for installing the new one. In the case of a Fluidmaster fill valve, you'll want to adjust the height to either match the one being replaced, or the more time-consuming (but not hard) method of marking the fill line of water on the tank, adjusting the fill valve to be just above that, then testing. Or ... is that another guide? For the present, I'd call this "removal." Perhaps we can create a new one for "installing a new fill valve." Ping me for assistance if needed.
David Spalding - Contestar
Hi David,
Thanks for checking out our guide! By default, all iFixit replacement guides conclude with "To reassemble your device, follow these instructions in reverse order." Our guide is intended to be a basic procedure that works for most fill valves. This particular fill valve is a Fluidmaster, and we do have an adjustment guide currently in the works. We'll also be updating our existing toilet guides, so make sure to check back soon.
We hope this clears everything up!
Kristen Gismondi -
Awesome guide!
It will definitely help him who wants to replace toilet fill valve by his own. I just want to know from my curiosity that , if I want to replace my fill valve should I also replace other parts like flapper or any other parts.
Thanks… :)
Rose Geiger - Contestar
Fluidmaster fill valve frequently fails to cut off, runs for awhile into overflow, THEN cuts off. Won’t cut off when manually toggled either. Water is hard, so could be lime deposit somewhere inside of valve. When water is turned off and tank drained for a couple of days, valve works for a few days. Any information appreciated.
Just Me - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 23
Ultimos 30 días: 113
Todo El Tiempo: 10,579
