Saltar al contenido principal
Titan Airless Sprayer IMPACT 410 Capacitor Replacement
Qué necesitas
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: paso 1, imagen 1 de 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: paso 1, imagen 2 de 2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: paso 2, imagen 1 de 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: paso 2, imagen 2 de 2
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: paso 3, imagen 1 de 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: paso 3, imagen 2 de 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: paso 3, imagen 3 de 3
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: paso 4, imagen 1 de 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: paso 4, imagen 2 de 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: paso 4, imagen 3 de 3
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: paso 5, imagen 1 de 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: paso 5, imagen 2 de 2
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: paso 6, imagen 1 de 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: paso 6, imagen 2 de 2
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: paso 7, imagen 1 de 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: paso 7, imagen 2 de 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: paso 7, imagen 3 de 3
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: paso 8, imagen 1 de 1
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: paso 9, imagen 1 de 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: paso 9, imagen 2 de 2
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: paso 10, imagen 1 de 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: paso 10, imagen 2 de 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: paso 10, imagen 3 de 3
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
Conclusión
Una persona más ha completado esta guía.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
161,942 Reputación
769 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,410 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 411
