Saltar al contenido principal
TMY V08 Lens Replacement
Qué necesitas
  1. TMY V08 Lens Replacement, Top Panel: paso 1, imagen 1 de 3 TMY V08 Lens Replacement, Top Panel: paso 1, imagen 2 de 3 TMY V08 Lens Replacement, Top Panel: paso 1, imagen 3 de 3
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
  2. TMY V08 Lens Replacement: paso 2, imagen 1 de 3 TMY V08 Lens Replacement: paso 2, imagen 2 de 3 TMY V08 Lens Replacement: paso 2, imagen 3 de 3
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
  3. TMY V08 Lens Replacement, Lens: paso 3, imagen 1 de 3 TMY V08 Lens Replacement, Lens: paso 3, imagen 2 de 3 TMY V08 Lens Replacement, Lens: paso 3, imagen 3 de 3
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
  4. TMY V08 Lens Replacement: paso 4, imagen 1 de 2 TMY V08 Lens Replacement: paso 4, imagen 2 de 2
    • Rotate the projector counterclockwise 90 degrees.
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
  5. TMY V08 Lens Replacement: paso 5, imagen 1 de 3 TMY V08 Lens Replacement: paso 5, imagen 2 de 3 TMY V08 Lens Replacement: paso 5, imagen 3 de 3
    • Rotate the projector counter clockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
  6. TMY V08 Lens Replacement: paso 6, imagen 1 de 2 TMY V08 Lens Replacement: paso 6, imagen 2 de 2
    • Flip the projector over so the bottom is facing up.
    • Remove the two 13.9 mm screws using a Phillips #1 screwdriver.
  7. TMY V08 Lens Replacement: paso 7, imagen 1 de 2 TMY V08 Lens Replacement: paso 7, imagen 2 de 2
    • Flip the projector back over.
    • Remove the fine gauge adjustment, by lifting it out.
  8. TMY V08 Lens Replacement: paso 8, imagen 1 de 3 TMY V08 Lens Replacement: paso 8, imagen 2 de 3 TMY V08 Lens Replacement: paso 8, imagen 3 de 3
    • Grasp the side of the lens.
    • Pull the lens outward away from the hole while pulling upward to remove the lens.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 39
Todo El Tiempo: 573
