Saltar al contenido principal
Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement
Qué necesitas
  1. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: paso 1, imagen 1 de 3 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: paso 1, imagen 2 de 3 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Case: paso 1, imagen 3 de 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: paso 2, imagen 1 de 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: paso 3, imagen 1 de 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: paso 4, imagen 1 de 2 Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement, Camera Lens: paso 4, imagen 2 de 2
    • Facing the front of the camera, remove the four 2.0 mm Phillips #0 black screws that hold the back of the motherboard to the case.
    • Release the four camera cable connections on the motherboard.
  5. Swann Wi-Fi Indoor Security Camera-Camera Lens Replacement: paso 5, imagen 1 de 1
    • Facing the back of the motherboard, remove the two 2.0 mm Phillips #0 screws connecting the camera to the motherboard.
Conclusión
Un comentario
is there a place i can buy a replacement lens for my swann security camera please
sn 10050062001244
Sonny Jobe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 1,075
