Saltar al contenido principal
Swann Wi-Fi Indoor Security Camera Microphone Replacement
Qué necesitas
  1. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: paso 1, imagen 1 de 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: paso 1, imagen 2 de 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Case: paso 1, imagen 3 de 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Microphone Replacement: paso 3, imagen 1 de 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: paso 4, imagen 1 de 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: paso 4, imagen 2 de 3 Swann Wi-Fi Indoor Security Camera Microphone Replacement, Microphone: paso 4, imagen 3 de 3
    • Locate microphone and pull to dislodge from the holder.
    • Disconnect the connector located on the main board to finish disconnecting the microphone.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 740
