Saltar al contenido principal
Supply Tube
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
  1. Supply Tube, Shutting off the Water Supply to a Toilet: paso 1, imagen 1 de 2 Supply Tube, Shutting off the Water Supply to a Toilet: paso 1, imagen 2 de 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  2. Supply Tube, Supply Tube: paso 2, imagen 1 de 3 Supply Tube, Supply Tube: paso 2, imagen 2 de 3 Supply Tube, Supply Tube: paso 2, imagen 3 de 3
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
Conclusión
Ron Davis
Miembro Desde 02/17/15
31,204 Reputación
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 126
