Saltar al contenido principal
Supersonic SC-777BT Motherboard Replacement
Qué necesitas
  1. Supersonic SC-777BT Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 Supersonic SC-777BT Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Pry open backing of the tablet using an iFixit opening tool.
  2. Supersonic SC-777BT Motherboard Replacement: paso 2, imagen 1 de 2 Supersonic SC-777BT Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a PH000 screwdriver to unscrew all four motherboard screws.
  3. Supersonic SC-777BT Motherboard Replacement: paso 3, imagen 1 de 3 Supersonic SC-777BT Motherboard Replacement: paso 3, imagen 2 de 3 Supersonic SC-777BT Motherboard Replacement: paso 3, imagen 3 de 3
    • Unscrew the holder of the camera and gently remove using tweezers.
    • Remove the sensors using tweezers.
  4. Supersonic SC-777BT Motherboard Replacement: paso 4, imagen 1 de 3 Supersonic SC-777BT Motherboard Replacement: paso 4, imagen 2 de 3 Supersonic SC-777BT Motherboard Replacement: paso 4, imagen 3 de 3
    • Detach the battery.
    • Battery is attached with adhesive; no tools needed to remove.
    • Using tweezers, lift and release the ribbon cable that was covered by the battery.
  5. Supersonic SC-777BT Motherboard Replacement: paso 5, imagen 1 de 2 Supersonic SC-777BT Motherboard Replacement: paso 5, imagen 2 de 2
    • Carefully remove the motherboard with your hands.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 292
