Saltar al contenido principal
Staples 34462 Electric Pencil Sharpener Power Cord Replacement
Qué necesitas
  1. Staples 34462 Electric Pencil Sharpener Power Cord Replacement, Cover: paso 1, imagen 1 de 1
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 2, imagen 1 de 1
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 3, imagen 1 de 1
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 4, imagen 1 de 1
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 5, imagen 1 de 1
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 6, imagen 1 de 1
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 7, imagen 1 de 1
    • Carefully pull the cover from the top panel and set it aside.
  8. Staples 34462 Electric Pencil Sharpener Power Cord Replacement, Power Cord: paso 8, imagen 1 de 1
    • Orient the panel with the power cord so that it is facing you.
    • Using a Phillips00 screwdriver, remove the two flat head 8.95mm screws securing the cord.
  9. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 9, imagen 1 de 1
    • Using a Phillips00 screwdriver, remove the two 10.42mm screws on the plastic frame securing the power component.
  10. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 10, imagen 1 de 1
    • Carefully lift out the power component from the panel.
  11. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: paso 11, imagen 1 de 1
    • Use a utility knife to cut the black insulation tape from the wire.
    • Cut the power cord from the wires to remove it.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 564
