Introducción
If your pencil sharpener will not power on, there may be an issue with the power cord. See our troubleshooting guide for more information on this problem. If your power cord turns out to be the problem, then follow these steps to replace it.
Qué necesitas
Orient the panel with the power cord so that it is facing you.
Using a Phillips00 screwdriver, remove the two flat head 8.95mm screws securing the cord.
Una persona más ha completado esta guía.
