Saltar al contenido principal
Sony Xperia Z1s Rear Camera Replacement
Qué necesitas
  1. Sony Xperia Z1s Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 1
    • Insert the opening pick in the crease between the body of the phone and the phone's back cover.
    • Slide the opening pick around the crease until the back cover releases from the phone.
  2. Sony Xperia Z1s Rear Camera Replacement: paso 2, imagen 1 de 1
    • Using the T4 Torx screwdriver, remove the five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Rear Camera Replacement: paso 3, imagen 1 de 1
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Rear Camera Replacement: paso 4, imagen 1 de 1
    • Use the opening pick to pry off the camera flex cable.
  5. Sony Xperia Z1s Rear Camera Replacement: paso 5, imagen 1 de 1
    • Use the opening pick to lift the camera out of the phone.
Conclusión
Una persona más ha completado esta guía.
Amanda Simmons
Miembro Desde 09/28/21
148 Reputación
1 Guía escrita
Equipo
Clemson, Team 4-4, Hunter Fall 2021 Miembro de Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 120
