Introducción
If your Sony Xperia Z1s (model C6916) does not turn on, your motherboard might require replacement.
The motherboard is the most important part of the phone and is required for proper operation. If your device is malfunctioning check the troubleshooting page of the device to help determine if the motherboard is the issue and needs replacement.
Before beginning this guide, turn off your phone completely and remove it from any external power source.
Qué necesitas
Insert the opening pick in the crease between the rear cover and the body of the phone.
Pry along the edge to lift and remove the back cover.
Use the opening pick to pry off the camera flex cable.
Continue to lift the flex cable upward until the camera pops out.
Una persona más ha completado esta guía.
