Saltar al contenido principal
Sony Xperia XA1 USB-C Module Replacement
Qué necesitas
  1. Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: paso 1, imagen 1 de 3 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: paso 1, imagen 2 de 3 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: paso 1, imagen 3 de 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 USB-C Module Replacement, Speaker: paso 2, imagen 1 de 3 Sony Xperia XA1 USB-C Module Replacement, Speaker: paso 2, imagen 2 de 3 Sony Xperia XA1 USB-C Module Replacement, Speaker: paso 2, imagen 3 de 3
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
  3. Sony Xperia XA1 USB-C Module Replacement: paso 3, imagen 1 de 3 Sony Xperia XA1 USB-C Module Replacement: paso 3, imagen 2 de 3 Sony Xperia XA1 USB-C Module Replacement: paso 3, imagen 3 de 3
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
  4. Sony Xperia XA1 USB-C Module Replacement: paso 4, imagen 1 de 2 Sony Xperia XA1 USB-C Module Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
  5. Sony Xperia XA1 USB-C Module Replacement: paso 5, imagen 1 de 3 Sony Xperia XA1 USB-C Module Replacement: paso 5, imagen 2 de 3 Sony Xperia XA1 USB-C Module Replacement: paso 5, imagen 3 de 3
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
  6. Sony Xperia XA1 USB-C Module Replacement, USB-C Module: paso 6, imagen 1 de 3 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: paso 6, imagen 2 de 3 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: paso 6, imagen 3 de 3
    • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
    • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
  7. Sony Xperia XA1 USB-C Module Replacement: paso 7, imagen 1 de 3 Sony Xperia XA1 USB-C Module Replacement: paso 7, imagen 2 de 3 Sony Xperia XA1 USB-C Module Replacement: paso 7, imagen 3 de 3
    • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
    • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
Conclusión
sebastianh034
Miembro Desde 02/14/23
253 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 38
Todo El Tiempo: 464
