Saltar al contenido principal
Sony Xperia XA1 Rear Camera Replacement
Qué necesitas
  1. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: paso 1, imagen 1 de 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: paso 1, imagen 2 de 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: paso 1, imagen 3 de 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: paso 2, imagen 1 de 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: paso 2, imagen 2 de 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: paso 2, imagen 3 de 3
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws near the top of the phone.
    • Use a spudger to gently pry the three tabs at the top of the phone.
  3. Sony Xperia XA1 Rear Camera Replacement: paso 3, imagen 1 de 3 Sony Xperia XA1 Rear Camera Replacement: paso 3, imagen 2 de 3 Sony Xperia XA1 Rear Camera Replacement: paso 3, imagen 3 de 3
    • Gently pry at the tabs until the cover comes free and is able to be removed.
    • Pull the piece up and set it aside. No cables are attached to the back.
  4. Sony Xperia XA1 Rear Camera Replacement: paso 4, imagen 1 de 3 Sony Xperia XA1 Rear Camera Replacement: paso 4, imagen 2 de 3 Sony Xperia XA1 Rear Camera Replacement: paso 4, imagen 3 de 3
    • Use an opening tool to release the back camera connector.
    • Gently pull the camera connector up to remove it.
    • Exercise caution when handling the rubber holder around the lens, as it can pop off easily.
Conclusión
sebastianh034
Miembro Desde 02/14/23
253 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 20
Todo El Tiempo: 184
