Saltar al contenido principal
Sony Xperia XA1 Audio Jack Replacement
Qué necesitas
  1. Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: paso 1, imagen 1 de 3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: paso 1, imagen 2 de 3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: paso 1, imagen 3 de 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Audio Jack Replacement, Audio Jack: paso 2, imagen 1 de 3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: paso 2, imagen 2 de 3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: paso 2, imagen 3 de 3
    • Use a Phillips #000 Screwdriver to remove the three 3 mm screws from the top bracket.
  3. Sony Xperia XA1 Audio Jack Replacement: paso 3, imagen 1 de 3 Sony Xperia XA1 Audio Jack Replacement: paso 3, imagen 2 de 3 Sony Xperia XA1 Audio Jack Replacement: paso 3, imagen 3 de 3
    • Use a spudger to gently pry the three tabs at the top of the phone and release the camera cover.
    • Gently lift the cover.
  4. Sony Xperia XA1 Audio Jack Replacement: paso 4, imagen 1 de 3 Sony Xperia XA1 Audio Jack Replacement: paso 4, imagen 2 de 3 Sony Xperia XA1 Audio Jack Replacement: paso 4, imagen 3 de 3
    • Use the Phillips #000 Screwdriver to remove the 3 mm screw to the left of the audio jack component.
    • Use an opening tool to lift the audio jack connector.
    • Pinch the connector and remove the audio jack.
Conclusión
Lindsey Taysom
Miembro Desde 02/14/23
205 Reputación
2 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 23
Todo El Tiempo: 206
