Saltar al contenido principal
Sony Xperia Sola Touch Screen Replacement
Qué necesitas
  1. Sony Xperia Sola Touch Screen Replacement, Touch Screen: paso 1, imagen 1 de 1
    • Lay the phone as shown and put the camera facing up.
  2. Sony Xperia Sola Touch Screen Replacement: paso 2, imagen 1 de 2 Sony Xperia Sola Touch Screen Replacement: paso 2, imagen 2 de 2
    • Push the back cover as shown, then lift the cover off.
  3. Sony Xperia Sola Touch Screen Replacement: paso 3, imagen 1 de 3 Sony Xperia Sola Touch Screen Replacement: paso 3, imagen 2 de 3 Sony Xperia Sola Touch Screen Replacement: paso 3, imagen 3 de 3
    • Remove the five screws as shown on the phone by using 26 Bit Kit.
    • Use a T6 screwdriver bit to remove top two screws.
    • Use a J000 screwdriver bit to remove the bottom two screws.
    • Use a T3 screwdriver bit to remove the middle screw (close to camera).
  4. Sony Xperia Sola Touch Screen Replacement: paso 4, imagen 1 de 2 Sony Xperia Sola Touch Screen Replacement: paso 4, imagen 2 de 2
    • Use plastic opening tool to remove the bottom white cover as shown.
  5. Sony Xperia Sola Touch Screen Replacement: paso 5, imagen 1 de 2 Sony Xperia Sola Touch Screen Replacement: paso 5, imagen 2 de 2
    • There are two additional screws under the bottom white cover as shown.
    • Use T3 drivers to remove two additional screws as shown.
  6. Sony Xperia Sola Touch Screen Replacement: paso 6, imagen 1 de 3 Sony Xperia Sola Touch Screen Replacement: paso 6, imagen 2 de 3 Sony Xperia Sola Touch Screen Replacement: paso 6, imagen 3 de 3
    • Using plastic opening tool, lift to remove the small black cover on the bottom left of phone as shown.
    • Then, using tweezers to lift the connector straight up to disconnect the battery's circuit as shown.
  7. Sony Xperia Sola Touch Screen Replacement: paso 7, imagen 1 de 3 Sony Xperia Sola Touch Screen Replacement: paso 7, imagen 2 de 3 Sony Xperia Sola Touch Screen Replacement: paso 7, imagen 3 de 3
    • Turn the phone onto its side and insert a flat object and gently remove cover, using plastic opening tool as shown.
  8. Sony Xperia Sola Touch Screen Replacement: paso 8, imagen 1 de 2 Sony Xperia Sola Touch Screen Replacement: paso 8, imagen 2 de 2
    • Lay the phone down as shown. Then use tweezers to pull additional power circuit up gently to remove it as shown.
  9. Sony Xperia Sola Touch Screen Replacement: paso 9, imagen 1 de 2 Sony Xperia Sola Touch Screen Replacement: paso 9, imagen 2 de 2
    • Repeat the last step as shown to remove additional power circuit which is on the top of the battery.
  10. Sony Xperia Sola Touch Screen Replacement: paso 10, imagen 1 de 2 Sony Xperia Sola Touch Screen Replacement: paso 10, imagen 2 de 2
    • After removing all connectors, Use the plastic opening tool to slide it under the top left of the board then lift the board straight up.
  11. Sony Xperia Sola Touch Screen Replacement: paso 11, imagen 1 de 3 Sony Xperia Sola Touch Screen Replacement: paso 11, imagen 2 de 3 Sony Xperia Sola Touch Screen Replacement: paso 11, imagen 3 de 3
    • Separate the screen from the touch screen sensor, use the spudger to do this job.
    • The left piece is the plastic screen.
    • The right piece is the touch screen sensor that you are looking to replace.
  12. Sony Xperia Sola Touch Screen Replacement: paso 12, imagen 1 de 3 Sony Xperia Sola Touch Screen Replacement: paso 12, imagen 2 de 3 Sony Xperia Sola Touch Screen Replacement: paso 12, imagen 3 de 3
    • Flip the touch screen sensor over and remove the battery from the back of it.
    • The battery might be glued on so some force might be needed.
Conclusión
3 personas más completaron esta guía.
Bo Wu
Miembro Desde 02/15/17
292 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G3, Lacy Spring 2017 Miembro de USF Tampa, Team S5-G3, Lacy Spring 2017
USFT-LACY-S17S5G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 572
