Saltar al contenido principal
Sony Xperia Sola Speaker Replacement
Qué necesitas
  1. Sony Xperia Sola Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Lay the phone as shown and put the camera facing up.
  2. Sony Xperia Sola Speaker Replacement: paso 2, imagen 1 de 2 Sony Xperia Sola Speaker Replacement: paso 2, imagen 2 de 2
    • Push the back cover as shown, then lift the cover off.
  3. Sony Xperia Sola Speaker Replacement: paso 3, imagen 1 de 3 Sony Xperia Sola Speaker Replacement: paso 3, imagen 2 de 3 Sony Xperia Sola Speaker Replacement: paso 3, imagen 3 de 3
    • Remove the five screws as shown on the phone by using 26 Bit Kit.
    • Use a T6 screwdriver bit to remove top two screws.
    • Use a J000 screwdriver bit to remove the bottom two screws.
    • Use a T3 screwdriver bit to remove the middle screw (close to camera).
  4. Sony Xperia Sola Speaker Replacement: paso 4, imagen 1 de 2 Sony Xperia Sola Speaker Replacement: paso 4, imagen 2 de 2
    • Use plastic opening tool to remove the bottom white cover as shown.
  5. Sony Xperia Sola Speaker Replacement: paso 5, imagen 1 de 2 Sony Xperia Sola Speaker Replacement: paso 5, imagen 2 de 2
    • There are two additional screws under the bottom white cover as shown.
    • Use T3 drivers to remove two additional screws as shown.
  6. Sony Xperia Sola Speaker Replacement: paso 6, imagen 1 de 3 Sony Xperia Sola Speaker Replacement: paso 6, imagen 2 de 3 Sony Xperia Sola Speaker Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using plastic opening tool, lift to remove the small black cover on the bottom left of phone as shown.
    • Then, using tweezers to lift the connector straight up to disconnect the battery's circuit as shown.
  7. Sony Xperia Sola Speaker Replacement: paso 7, imagen 1 de 3 Sony Xperia Sola Speaker Replacement: paso 7, imagen 2 de 3 Sony Xperia Sola Speaker Replacement: paso 7, imagen 3 de 3
    • Turn the phone onto its side and insert a flat object and gently remove cover, using plastic opening tool as shown.
  8. Sony Xperia Sola Speaker Replacement: paso 8, imagen 1 de 3 Sony Xperia Sola Speaker Replacement: paso 8, imagen 2 de 3 Sony Xperia Sola Speaker Replacement: paso 8, imagen 3 de 3
    • Flip over the black back cover and locate the speaker phone at the bottom, then use the tweezers to remove the speaker. It is glued to the back cover so a little force will be needed.
Conclusión
3 personas más completaron esta guía.
Bo Wu
Miembro Desde 02/15/17
292 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G3, Lacy Spring 2017 Miembro de USF Tampa, Team S5-G3, Lacy Spring 2017
USFT-LACY-S17S5G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 348
