Saltar al contenido principal
Sony Vaio VPCCW17FX RAM Replacement
Qué necesitas
  1. Sony Vaio VPCCW17FX RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX RAM Replacement: paso 2, imagen 1 de 1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX RAM Replacement: paso 3, imagen 1 de 2 Sony Vaio VPCCW17FX RAM Replacement: paso 3, imagen 2 de 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX RAM Replacement: paso 4, imagen 1 de 2 Sony Vaio VPCCW17FX RAM Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
  5. Sony Vaio VPCCW17FX RAM Replacement: paso 5, imagen 1 de 1
    • Lift the black plastic cover to assess the RAM.
  6. Sony Vaio VPCCW17FX RAM Replacement: paso 6, imagen 1 de 3 Sony Vaio VPCCW17FX RAM Replacement: paso 6, imagen 2 de 3 Sony Vaio VPCCW17FX RAM Replacement: paso 6, imagen 3 de 3
    • Apply light, outward pressure to the locks on both sides of the RAM.
    • Rotate the RAM up and slowly pull towards you to remove it.
  7. Sony Vaio VPCCW17FX RAM Replacement: paso 7, imagen 1 de 3 Sony Vaio VPCCW17FX RAM Replacement: paso 7, imagen 2 de 3 Sony Vaio VPCCW17FX RAM Replacement: paso 7, imagen 3 de 3
    • In order to remove the secondary RAM, use the same outward pressure on the locks.
    • Lift and slide out the RAM to remove it from the slot.
Conclusión
Mia Martinez
Miembro Desde 03/30/17
101 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S8-G5, Bennett Spring 2017 Miembro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 1,227
