Saltar al contenido principal
Sony SRS-XE200 Speaker Assembly Replacement
Qué necesitas
  1. Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: paso 1, imagen 1 de 2 Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: paso 1, imagen 2 de 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Speaker Assembly Replacement: paso 2, imagen 1 de 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Speaker Assembly Replacement: paso 3, imagen 1 de 2 Sony SRS-XE200 Speaker Assembly Replacement: paso 3, imagen 2 de 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Speaker Assembly Replacement: paso 4, imagen 1 de 2 Sony SRS-XE200 Speaker Assembly Replacement: paso 4, imagen 2 de 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
82,729 Reputación
202 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,449 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 142
