Saltar al contenido principal
Sony SRS-XB43 Speaker Replacement
Qué necesitas
  1. Sony SRS-XB43 Speaker Replacement, Faceplate: paso 1, imagen 1 de 2 Sony SRS-XB43 Speaker Replacement, Faceplate: paso 1, imagen 2 de 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Speaker Replacement: paso 2, imagen 1 de 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Speaker Replacement: paso 3, imagen 1 de 1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Speaker Replacement: paso 4, imagen 1 de 2 Sony SRS-XB43 Speaker Replacement: paso 4, imagen 2 de 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Speaker Replacement, Speaker: paso 5, imagen 1 de 3 Sony SRS-XB43 Speaker Replacement, Speaker: paso 5, imagen 2 de 3 Sony SRS-XB43 Speaker Replacement, Speaker: paso 5, imagen 3 de 3
    • On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
    • Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
    • This step prevents the cable from getting in the way of the right speaker as it is being removed.
  6. Sony SRS-XB43 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove eight black 10 mm screws attached to the speaker plate using a Phillips #1 screwdriver.
  7. Sony SRS-XB43 Speaker Replacement: paso 7, imagen 1 de 2 Sony SRS-XB43 Speaker Replacement: paso 7, imagen 2 de 2
    • Remove the two individual speakers.
Conclusión
Una persona más ha completado esta guía.
Bishoy Mikhail
Miembro Desde 10/26/22
253 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Miembro de UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 53
Todo El Tiempo: 991
