Saltar al contenido principal
Sony SRS-XB43 Battery Replacement
Qué necesitas
  1. Sony SRS-XB43 Battery Replacement, Faceplate: paso 1, imagen 1 de 2 Sony SRS-XB43 Battery Replacement, Faceplate: paso 1, imagen 2 de 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Battery Replacement: paso 2, imagen 1 de 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Battery Replacement: paso 3, imagen 1 de 1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Battery Replacement: paso 4, imagen 1 de 2 Sony SRS-XB43 Battery Replacement: paso 4, imagen 2 de 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Battery Replacement, Battery: paso 5, imagen 1 de 2 Sony SRS-XB43 Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
    • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
    • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
  6. Sony SRS-XB43 Battery Replacement: paso 6, imagen 1 de 3 Sony SRS-XB43 Battery Replacement: paso 6, imagen 2 de 3 Sony SRS-XB43 Battery Replacement: paso 6, imagen 3 de 3
    • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
    • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
  7. Sony SRS-XB43 Battery Replacement: paso 7, imagen 1 de 2 Sony SRS-XB43 Battery Replacement: paso 7, imagen 2 de 2
    • Orient the plastic chassis so that the port housing PCB is facing upward.
    • Remove the plastic black film covering the battery, leaving the blue battery exposed.
  8. Sony SRS-XB43 Battery Replacement: paso 8, imagen 1 de 2 Sony SRS-XB43 Battery Replacement: paso 8, imagen 2 de 2
    • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
    • Using your fingers, pull upwards until the battery is removed from its enclosure.
    • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
Conclusión
2 personas más completaron esta guía.
Luke Escobar
Miembro Desde 10/28/22
159 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Miembro de UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Miembros
5 Guías creadas
Un comentario
So, where can we buy a new battery to use these instructions for replacing it ?
Doubletap - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 34
Ultimos 30 días: 167
Todo El Tiempo: 2,296
