Saltar al contenido principal
Sony PS1100 Needle Cartridge Replacement
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: paso 1, imagen 1 de 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: paso 1, imagen 2 de 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: paso 1, imagen 3 de 3
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: paso 2, imagen 1 de 1
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: paso 3, imagen 1 de 2 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: paso 3, imagen 2 de 2
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: paso 4, imagen 1 de 1
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
Conclusión
Una persona más ha completado esta guía.
L Cis
Miembro Desde 10/10/14
110 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-8, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-8, Donnelly Fall 2014
USFT-DONNELLY-F14S1G8
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 4,692
