Introducción
Removing the lens mount is a quick process that is fully outlined by this guide.
Qué necesitas
If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
Pull the card out with your fingers.
First, turn the camera upside down.
Press the button located next to silver lens mount and rotate the lens counterclockwise.
Pull the lens away from the camera body.
With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
5 personas más completaron esta guía.
