Saltar al contenido principal
Sony Cyber-shot DSC-W150 Back Casing Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W150 Back Casing Replacement, Back Casing: paso 1, imagen 1 de 1
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Sony Cyber-shot DSC-W150 Back Casing Replacement: paso 2, imagen 1 de 1
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
  3. Sony Cyber-shot DSC-W150 Back Casing Replacement: paso 3, imagen 1 de 1
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
  4. Sony Cyber-shot DSC-W150 Back Casing Replacement: paso 4, imagen 1 de 1
    • On the left side of the camera, remove the two silver screws using the screwdriver.
  5. Sony Cyber-shot DSC-W150 Back Casing Replacement: paso 5, imagen 1 de 1
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
  6. Sony Cyber-shot DSC-W150 Back Casing Replacement: paso 6, imagen 1 de 1
    • After detaching the back cover, carefully pull it off.
  7. Sony Cyber-shot DSC-W150 Back Casing Replacement: paso 7, imagen 1 de 1
    • The back cover should now be separated from the camera.
Conclusión
4 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 5,149
