Saltar al contenido principal
Sony Cyber-shot DSC-H20 Lens Assembly Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: paso 1, imagen 2 de 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 2, imagen 1 de 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 3, imagen 2 de 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 4, imagen 1 de 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 4, imagen 2 de 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 4, imagen 3 de 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 5, imagen 1 de 1
    • Place the camera upside down with the battery port positioned upward and the battery port open.
  6. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 6, imagen 1 de 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 6, imagen 2 de 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 6, imagen 3 de 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 7, imagen 1 de 1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 8, imagen 2 de 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 9, imagen 1 de 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 9, imagen 2 de 2
    • Lift up the gray plastic facing in order to uncover the motherboard and the ribbon cable ports.
  10. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 10, imagen 1 de 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 10, imagen 2 de 2
    • Carefully flip up the three black clasps holding the lens cables to the motherboard.
    • Slide the cables from the ports.
  11. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: paso 11, imagen 1 de 1
    • Lift the lens and attached ribbon cables from the camera in order to switch this lens with a new one.
Conclusión
Una persona más ha completado esta guía.
Rachel Payne
Miembro Desde 02/23/15
386 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Leahy Winter 2015 Miembro de USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 40
Todo El Tiempo: 2,683
