Saltar al contenido principal
Sony Cyber-Shot DSC-W830 LCD Replacement
Qué necesitas
  1. Sony Cyber-Shot DSC-W830 LCD Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 LCD Replacement: paso 2, imagen 1 de 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 LCD Replacement: paso 3, imagen 1 de 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: paso 4, imagen 1 de 3 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: paso 4, imagen 2 de 3 Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: paso 4, imagen 3 de 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 LCD Replacement: paso 5, imagen 1 de 3 Sony Cyber-Shot DSC-W830 LCD Replacement: paso 5, imagen 2 de 3 Sony Cyber-Shot DSC-W830 LCD Replacement: paso 5, imagen 3 de 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 LCD Replacement: paso 6, imagen 1 de 3 Sony Cyber-Shot DSC-W830 LCD Replacement: paso 6, imagen 2 de 3 Sony Cyber-Shot DSC-W830 LCD Replacement: paso 6, imagen 3 de 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: paso 7, imagen 1 de 2 Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: paso 7, imagen 2 de 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 LCD Replacement: paso 8, imagen 1 de 2 Sony Cyber-Shot DSC-W830 LCD Replacement: paso 8, imagen 2 de 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: paso 9, imagen 1 de 2 Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: paso 9, imagen 2 de 2
    • Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
    • Be careful when lifting the LCD screen; the ribbon cable will still be attached.
  10. Sony Cyber-Shot DSC-W830 LCD Replacement: paso 10, imagen 1 de 2 Sony Cyber-Shot DSC-W830 LCD Replacement: paso 10, imagen 2 de 2
    • Grasp the no-fuss ribbon cable and gently pull it out from the motherboard.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team 17-1, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Miembros
6 Guías creadas
5 comentarios
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
tajbhatnagar - Contestar
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Tamil Varshitha - Contestar
Sony dsc s2000 model camera need
Display & lens unit
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 41
Todo El Tiempo: 4,210
