Saltar al contenido principal
Sony BDP-s7200 Motherboard Replacement
Qué necesitas
  1. Sony BDP-s7200  Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200  Motherboard Replacement: paso 2, imagen 1 de 2 Sony BDP-s7200  Motherboard Replacement: paso 2, imagen 2 de 2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200  Motherboard Replacement: paso 3, imagen 1 de 2 Sony BDP-s7200  Motherboard Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200  Motherboard Replacement: paso 4, imagen 1 de 1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: paso 5, imagen 1 de 3 Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: paso 5, imagen 2 de 3 Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: paso 5, imagen 3 de 3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200  Motherboard Replacement: paso 6, imagen 1 de 2 Sony BDP-s7200  Motherboard Replacement: paso 6, imagen 2 de 2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200  Motherboard Replacement: paso 7, imagen 1 de 3 Sony BDP-s7200  Motherboard Replacement: paso 7, imagen 2 de 3 Sony BDP-s7200  Motherboard Replacement: paso 7, imagen 3 de 3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200  Motherboard Replacement: paso 8, imagen 1 de 2 Sony BDP-s7200  Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
  9. Sony BDP-s7200  Motherboard Replacement, Motherboard: paso 9, imagen 1 de 2 Sony BDP-s7200  Motherboard Replacement, Motherboard: paso 9, imagen 2 de 2
    • Remove the ribbon cables connected to the front panel board.
    • Pull firmly, but not too hard as to not damage the ribbon cable.
  10. Sony BDP-s7200  Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the cable connected to the power supply.
  11. Sony BDP-s7200  Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove the ribbon cables that connect the motherboard to the disk drive.
    • Pull firmly, but not too hard as to not damage the ribbon cables.
  12. Sony BDP-s7200  Motherboard Replacement: paso 12, imagen 1 de 3 Sony BDP-s7200  Motherboard Replacement: paso 12, imagen 2 de 3 Sony BDP-s7200  Motherboard Replacement: paso 12, imagen 3 de 3
    • Remove the three screws using the Phillips #2 Screwdriver.
    • Do not attempt to remove. There is one additional screw on the back of the device.
    • Remove the screw on the back of the device with the same screwdriver.
  13. Sony BDP-s7200  Motherboard Replacement: paso 13, imagen 1 de 2 Sony BDP-s7200  Motherboard Replacement: paso 13, imagen 2 de 2
    • Lift the motherboard from the front and carefully pull it out.
    • There is a small square adhesive on the bottom. Leave it there for reassembly.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 483
